hi,
some months ago a set of drops started to fall in the floor of my garage under the rear part of the e9, in the diff area
now i am sure that the diff is leaking from the front side, in which the seal probably is worn
so i am now in the position of changing the shaft seal (ref. N. 5 in the following drawing)
but one question arises: you might know that in a diff the part number 7 (clamping bush) has to be preloaded when the diff is mounted, that preload modifies the part geometry and it is said that if you need to repair the diff and if you dismantle it, you will always need a new clamping bush
the question then: if i intend only to change the shaft seal (green arrowed ref. 5) just undoing the nut number 3, remove parts 1, 4, and 5, and replace part 5 with a new one, do you think i will need to install a new clamping bush, preload it and so on ?
thanks for your answers
regards
regards
