Apparantly somewhere along the line the passenger front strut has been replaced, the problem is that the collar for the new Bilstein doesnt fit - this strut has a smaller diameter collar and threads, although the tube diameter is the same and both original Boges were in place. The correct strut reads "385 01" and the other one reads"386 198D R"
Does anyone know what car this would have come from, other than this the collar diameter it appears identical to the correct strut. It appears my options are to:
1. Get a new passenger strut
2. Get the correct Bilstein and collar for this strut
UPDATE: Since posting this I read a previous post from SFDon that there were 3 different struts and 2 different ring nuts (48mm and 50mm) so it appears I have one of each, is it possible to get a 48mm Bilstein ring nut for my P36-0024 insert?
Option 2 sounds less expensive - any advice is appreciated, at present my spring/shock project is dead in the water. Thanks.
Incorrect one:
Correct one:
Both:
Incorrect collar on left, correct one on right:
Incorrect one:
Correct one:
Both:
