New Steel Lines
Nicad
Toronto
I see some corrosion on the rear brake line, so will be replacing all of it and the fuel line. I am assuming you cannot buy brake lines that are preformed and must bend them to fit? DOes anyone have any tips on how to best do this? I thought I would cut my existing line in two foot sections and use these sections to help bend the new line a bit at a time. Should I just buy shorter lines and attach them together with fittings or attempt to do a one piece line from master to the rear? I have never used a flaring tool, so if anyone knows which type of flare the E9 uses that would be helpful. I suppose I could reuse the fittings.
Tia
I would not cut the existing lines. You will want them whole so you can copy all the bends for the new ones exactly. There are probably places that will bend them for you (if you have the originals intact). You can buy a kit of straight lines from W& N (and probably others) already flared with fittings. I found a place out east (ClassicTube) that made up a set of SS brake and two SS fuel lines for me. They were kind of pricey. Others here may have a better source for stainless options.
The lines from BMW that I have seen had soft tubing that was pretty easy to bend the first time. After that, the metal was work-hardened and harder to bend, so best to get it right the first time! Having the old lines for patterns makes the job a lot easier.
BMW lines
Yes, the BMW lines was very easy to work with. It's some kind of copper alloy. Possible the same as in 61porsches link above.
As I remember there were not very pricey. BMW original parts are always BMW... :-)
This might be of use, m10 to m10 BMW brake lines - part number/length (mm)
P/N Length
34326755545 100
34326755547 149
34326755548 158
34326755320 162
34326755550 205
34326755551 214
34326755552 222
34326755553 240
34326755555 260
34326755556 270
34326755328 283
34326755560 310
34326755562 330
34326755563 340
34326755564 350
34326755565 360
34326755567 380
34326755569 400
34326755571 420
34326755306 448
34326755576 470
34326755578 490
34326766270 523
34323412744 544
34326755582 560
34326772472 606
34326755585 620
34326755586 645
34326772563 668
34326755588 685
34326755589 703
34326755591 751
34326755592 780
34326755594 829
34326755595 841
34326755596 862
34326755597 886
34326755598 900
34326755600 940
34326755601 963
34326755602 985
34326755314 1005
34326755604 1012
34326755607 1080
34326755610 1146
34326755612 1175
34326755616 1260
34306779187 1352
34326755622 1402
34326755623 1447
34322283835 1525
34326755342 1526
34326765639 1612
34326755633 1637
34326755634 1656
34326755636 1705
34326755638 1764
34326755640 1845
34326755641 1870
34326755643 1920
34326755646 1980
34326755649 2039
34326755650 2056
34326755651 2074
34326755653 2109
34326755654 2143
34326755656 2200
34326755657 2224
34326755658 2235
34326755660 2272
34326755663 2338
34326755664 2368
34326755666 2436
34326755667 2503
34326772506 2590
34326755670 2657
34326755671 2691
34326755673 2770
34326755316 2817
34326755674 2840
34326755121 2915
34326755680 2980
34326755683 3048
34326755684 3075
34326755686 3120
34326755689 3170
34326755693 3275
34326755695 3315
34326755700 3560
34326755344 3568
34326755703 3672
34321153845 3740
34326755706 3850
34326755712 4300
34326755715 4372
34326755716 4587
Thanks for that Link 61 Porsche. I am impressed with the tips you come up with. Bill, did you buy pre bent lines from BMW or ones with ends already on them in individual lengths? Stefan, I tried the part numbers in you message at Tisher BMW and came up empty.
Anyway, it looks like I have some good options. WHen running the from lines across the firewall it looks like I will destroy that factory insulation if I make the slightest mistake. Is that part still available? Mine is in pretty good condition, but looks fragile.
