check please the engine control parameters
hello,
I have finished a long project to install some additional gauges in my car to cross-check some key parametres of the engine, and the results are here, can you please tell me if the values are correct:
volts at contact: 12v
volts engine on: 14v
water temp: 85ºC (200ºF aprox)
oil temp 80ºC
oil press at iddle = 2,2 bar
oil press at 3000rpm`s = 3,5 bar
see pics:
volts contact only
engine warmed up
general view of gauges at iddle
volts iddle
wsater temp iddle
oil temp and press at iddle
oil temp and press at 3000rpm`s
Engine variables
Looks right.
Voltage at rest- 12.7. Should be the same as the battery. Anything below 12.5 - check your battery. So the guage could be off just a little?
Looks right.
well if i look carefully to that pic, probably i was not very accurate in my description, its more like 12,5 volts, the view angle of the pic is not helping
regards and thanks
Hey deQuincy,
Not sure if you've covered this elsewhere, but can you post some details on how / where you mounted the oil temp sender and what part this was (and where you got it).
After posting my previous reply to your gauge cluster build thread I've just remembered that my oil temp gauge reads looooow - Think it's because I have the sender screwed into the bottom of the sump through the plug.
Thanks.
Hey deQuincy,
Thanks.
hi, the oil temp sender is explained in the thread you mentioned
detail of how it was done in this thread:
http://www.e9coupe.com/forum/showthread.php?t=7419
