nick
Does anyone sell negative camber plates exempt from bimmerdoc?
regards
nick
regards
nick
I've got plates from ground control. They are fully adjustable for both camber and caster.
Not quite what you're asking for, but fully adjustable is a good thing.
They have a plate for the E9 and 2002. http://www.ground-control-store.com/products/description.php/II=665/CA=97
Now that I'm reading it again though, these plates do not work with stock springs. That worked for me as I was going to a coil over anyway.
They sold me a slip on adjuster that used the stock spring perch so I didn't have to do any welding to the strut housing to convert to coil overs.
I think we went with something like 6.5" long springs. The coil over kit for the 2002 is similar to what they put together for me.
http://www.ground-control-store.com/products/description.php/II=16/CA=102
In the rear I just cut the springs.![]()
Not sure who makes these. NMNA, can't vouch for quality or function.
Most modern tires need more camber than the factory has provided for older BMW's.
who cares, if you are buying this type of plate, why not buy it from LaJolla Independent for 5 dollars less - everyday price. LJI sells these for 80 bucks a pair. support the people who support us.Not sure who makes these. NMNA, can't vouch for quality or function.
http://www.ebay.com/itm/BMW-E9-Coup...ash=item488841f179:g:dKsAAOxyOlhStLBf&vxp=mtr
