With my mother in-law visiting last week, I found myself in the garage more than usual and finally got around to some of the little things that I've been putting off for too long. One thing was replacing the door brakes. I didn't think of taking photos in-process but here are the highlights.
--Interior bits and door card off, find three (THREE!) broken spring halves. Hopefully, this will be the last time this car gets a new door brake. I chucked the first one but then found two more when I thought about checking the bottom of the door for debris (see photo). The door brake strap had a funny bend on the roller axle opposite the mounting rivet (right end of the strap in the photo) but, I didn't find the rollers in the door!?! The bend made me look closely at the opening of the door...
--and I found that the sheet metal is bulged out both above and below the opening for the door strap which you might be able to see in the "after" photo below. Nothing like using sheetmetal as the door stop.
--Lastly, has anybody else had to cut/grind down the inboard-most portion of the mounting face in order to get the bolts to line up? I probably removed 1/4" of material from the body of the mount before I could get it anywhere near the spot it needed to be. Just wondering if the door is bent a little more than I first saw.
