Well, I analyzed the box thoroughly and here is what I've found: The design and construction are exactly as the original with no modifications whatsoever. The material used from what I can tell is still the very hard and rigid plastic like the original, although the lower hinged shell appears to be a slightly softer plastic. In all probability, the new box will likely crack like the old version, but hey, until then, I will enjoy it while it holds up. Appears the tool holder is made of a softer rubber material than the original closed cell dense foam, so it may not disintegrate quite as easily as the original. Conclusion...all in all, a quality manufactured product that is desperately needed by coupe enthusiasts. Thank you BMW!
