Marchal Homologation mark question
Hello! I ran with Marchal headlights since a teenager, let's say since about 1971 or so. The larger size (US calls it 7 inch), I loved them to pieces! No nipples, but you can't have everything... Still, each single unit had a low beam reflector with H1 lamp, and a separate high beam reflector with an H3 lamp. I put relays in my 1972 2002 for each circuit, and ran both high and low together as Euro cars do. Sadly, they met their demise in the back end of a Honda. :sad:
So this thread caught my eye. Grabbed me by the you know what, is more like it... :lol:
On your question about markings- I have posed this question to my US lighting guy, see what he knows. He's been most helpful with my lighting questions, and is noted on many forums. It's Daniel Stern Lighting Consultancy.
You likely already know, the directions call them "Cornering - Fog" lights, and the note about the nipples blocking glare for oncoming traffic makes perfect sense, since the lamps do not have a mask as newer lamps do.
I also love the installation, very original looking, and executed like a pro! Congratulations on the installation, it really adds to the car's abundant beauty and competent lighting equipment.
EDIT -- Just heard back from DSL.
Apparently these are being copied by a (guess who) Chinese firm, as you may expect.
I quote:
"Maybe the ones you linked are in fact NOS actual real Marchal. But the odds of finding actual real NOS Marchals is relatively quite tiny."
So, if these are the genuine article, undoubtedly they are a score!  but ...
"Don't be quite so sure as all that...
http://www.primaautocraft.com/en/products_detail.asp?id=73
http://www.primaautocraft.com/en/products_detail.asp?id=74
"That is just two of _many_ variants on this lamp made by this guy in China. Visually, the lamps are beautiful and quite perfect in every way, and I mean EVERY way, right down to the correct inks and fonts on the labels on the backs of the reflectors, correct "MARCHAL" engravings in the metal parts, olde-tyme date stamps, correct terminals on the correct braided wire, exact-repro instruction sheets, etc.
But optically they are a complete zero. They light up, but they do not produce anything like a useful, usable, safe, or effective beam pattern."
I would love to analyze the beam pattern, see if they are 'Sacrebleu!' ou 'Formidable!'
Do you have any pics of their output pattern against a flat wall at night?
But, that's just me; I do not think they are any less beautiful.
And regarding the A1413, he says " these lamps pre-date the unified European code."
If you need an inspector's approval, I'd just pull the fuse and tell them the lights are 'For Show Purposes Only'.
Hope this helps!
