Trev
My clutch when out last weekend. I was able to get it home and get it into the garage. I can still get into gear but its a pain, I'm assuming its best to have it towed to the shop and not try and drive it there myself. Thoughts?
Well Trev, I see you're new here, and we have no idea of your mechanical capabilities. Let me suggest that a clutch usually doesn't suddenly "go out" as you stated. What's more likely is a gradual loss of fluid in the reservoir, or a leaking clutch master or slave cylinder.
Before you call an expensive flatbed towtruck, a little diagnosis is likely to save you some coin. A more detailed description is what's needed.
If you're not mechanically capable or for whatever reason unlikely to do some work yourself, then and only then should a truck be called. We are here to help but need something more specific from which to give useful advice. These cars have been around a while, and so have many of their owners, and we know where and how the common faults occur.
Sometimes the master will not leak on the floor outside the car butinto the carpet area behind the pedal. Pull back the carpet and you will feel the padding damp. Good luck
