3.0CS... Fjord probably going Baikal blue
3.0CS
Hi guys:<O:p</O:p
<O:p</O:p
I live in Mexico and down here, e9's are not very common. Either they got imported from new by very wealthy or influential guys, or in the past number of years when our borders opened for 'collector' cars (paying a huge amount of taxes regularly). I have always liked e9's and considered them the most beautiful BMW ever (asides from the gorgeous 507 roadster). Back some 30 years ago, I wanted my father to purchase one, out of a guy that had two, a cream colored one with tan interior, and the one I wanted, a baikal blue one with tan interior, but the owner backed out of the deal, once we were at his place and with the money in hand.<O:p</O:p
<O:p</O:p
Anyhow, fast forward 30 years later, and after having gotten some other old toys and restored a few, I bought a 1974 BMW 3.0CS, sunroof, air conditioning, and standard transmission... all of those options add up to what I call an excellent option for a daily driver. That is the intention with the car, to become a very nice and driveable car, done as close to original as posible and to be used once or twice a week.
<O:p</O:pOf course, it has a couple of defects for which it is not perfect: 1974 US version, so it has the ugly bumpers, and also the color combo is not my favorite, the very light blue (fjord metallic, if I recall correctly) with tan leather (plastic nowadays). Luckily, I believe both things could be corrected easily when I want to.
<O:p</O:pAbout the car's condition, it is far from great, but not bad either. The car shows very little signs of rust, so I am sure it will be no problem at all to restore. We did repair the roof already which was rusted in parts due to blocked sunroof drains and I believe that is the worst part the car had. It is mostly complete, missing a few pieces of trim or bits. It shows a sort of bad paint, in an incorrect tone of blue, a 10 footer, so a new paint job will be needed in the medium term.
<O:p</O:pMechanically, after some work, the car is very dependable and drives very nicely, solid and smooth, but it smokes a bit, and after compression checks and several tests, my mechanic determined it was valve seals, most probably. We already dismantled the engine bay area a bit and took the head off and yes, valve seals are urgently needed.
<O:p</O:pCarbs are not original, and the fuel pump is Italian and appears to be very small, but works fine except after stopping the car on a very hot day, so I installed an electric unit in line, near the tank, to help with startups.
<O:p</O:pAbout the car's future, I already said it will become a daily driver, shared with some other old toys in the stable, mainly a '67 Porsche 912, a '60 MB 190SL and a '64 Buick Riviera.
<O:p</O:pAt first, I thought only about changing the interior to navy blue, but now that I have the engine out, I have to decide if I want to go to a color I like... and as you probalby correctly sensed, I would kill for Baikal blue. So, in these few weeks, with the engine partially disassembled, we will prepare the engine bay area for paint... and I probably have around 3 weeks to decide if I go ahead with the baikal change or return it to Fjord, but with a properly painted engine bay area.
<O:p</O:pIntention then is to use the car with the same 10 footer exterior job for a while till I finish some other projects and then do the full cosmetics, the exterior paint job, the new leather interior, new rubber, etc.
<O:p</O:pAnyhow... probably enough for a small introduction. I should better leave you with a few pics... in case I find out how to do it in my next post.
<O:p</O:pLooking forward to getting help from the list to restore the car correctly.
<O:p</O:pVictor<O:p</O:p
Pics
Let's see if this works... I have to admit I am kind of dumb with computers...
And a few more...
Looks nice. I like the tan interior with whichever blue you paint the car.
The clock is probably not working, and I would consider a subtler steering wheel
once you restore it. Great chance to paint the engine bay. There is one part that should be painted black (cover above the wiper motor).
DeQuincey had a stash of original West German fuel pumps if you need that.
Good luck.
Yes Arde, you are right... the clock is not working. It does make sound but has a stripped plastic gear in there... so I need to locate another one.
About the steering wheel, what I have now is not original? I wouldn't mind changing it for a nicer one as long as it is original.
Thanks for the lead on fuel pumps!
Clock can be done at palo alto speedo
Make sure you put a head on from after 1972
Carbs are available from david rumbarger
Where in Mexico?
The head, so far, looks fine. It is only the valve seals that are very much gone... broken, stiff... but being a '74 I am hoping it will not have whatever the problems that make you suggest to use a post '72 head.
Thanks for the tips on clock and carbs. I will look into that a bit later. The car worked so good with what it has now, that I will keep it as is for a while, while I find a set of original Zeniths in good condition.
I live in Querétaro, 2 hours north of Mexico city.
Thanks!
Steering wheel is likely original, as I hear that they went towards more plasticky and cheaper steering wheels in 74 and 75. If you want the golden years look (72 of course...) then there are other variants including the Nardis for a wooden accent...
Thanks! Noted, though I am hoping my head will be ok. We will be taking it to a machine shop to check on everything.
I am having a problem with Baikal blue. I remember the color as a médium grayish blue, rather intense. I had my paint shop look for the code and they came up with something which resembles it but much lighter. How can I find the correct shade of Baikal blue?
