Ken Wolkens
- Messages
- 12
- Reaction score
- 0
Still working on the 1973 with a friend that has undergone a lengthy restoration and have hit a dead end on how the electric fan is controlled.
We have traced the harness for the fan motor back to the passenger side front fender just behind the grille opening radiator (GOR) support. There is nothing there except the heavy gauge wires leading to the fan. After jumping 12 volts to the fan wire we find the motor works perfectly so now we need to figure out what's missing.
FWIW, there are two sensors that are mounted in the right upper side of the radiator side tank that look like temp sensors or temp switches but no wires going to them.
I assume there should be some sort of fan control relay that was mounted in the right front area of the engine compartment either on the fender apron or the GOR but there is nothing there and it also looks as if a few wires have been chopped off.
We have the schematic diagram from eBay and the Haynes service manual but neither of them even acknowledge that an electric fan exists.
Any help, insight or schematics will be greatly appreciated.
Thanks, Ken Wolkens
Thanks, Ken Wolkens
