Smog everything has come off the 73 3.o CSA. What is the correct setup for all the various nipples? And how to handle the distributor? Thanks.
I run my VA on full manifold vacuum along with my vacuum gauge, everything else is plugged.
This is kind of where I was headed...but what about the 2 nipples on the bottom of the stock air cleaner? Ignore them and plug their sources?
Thanks for the replies by the way. I'm usually on the E23 forum and it can take a week to get this much input.
Someone posted a picture of a green 2800CS convertible, asking about it. I built it. A long time ago.
Search indicates it might be smart to connect 2 engine-side ported nipples together (one each carb) and then use that T'd on to the vacuum advance, leaving the retard open.
And then running a balance line between the 2 smaller nipples on the battery side.
Which leaves the question of the larger manifold to air cleaner can line and then the smaller air cleaner to valve cover nipple.
Comments?
