Spares needed if you can help
pmallinson
Owston Ferry Doncaster uk
Hi
My car had Air Con originally but the PO removed all the parts (saying it was power sapping !) anyway the internal center console still have the air con controls on it and hence I would like to replace this with a standard (none AC) piece instead so I need the black plastic piece that fits above the radio if anyone can help me out ? of tell me any supplier that may have them still in stock ?
I hope you've seen pictures of the non-AC cars. The radio is relocated up to where the panel you want to replace is now, then there's empty space below, a wood "floor" with black non-skid strips. Suggest you could take out that AC control panel and relocate the radio for a clean look.
I like that non-AC look a lot, more so since I've removed the underhood AC bits from my coupe and am left with the same console situation you have (although in left hand drive format).
Thanks for that I had assumed it was just a black 'slotted' panel that went int there, I will have to see if I can see pictures with the radio up there and then see what I need for below to replace existing raido position
Thanks a million
