Thoughts on engine removal
Use a high volume low pressure spray gun If you have a low CFM compressor.You can buy a very good gun I am using a 60 gallon 10-11 ccfm rom Home Depot. We painted my car using an old DeVilbas gun. I get lots praise on the quality. I will ad that we used approximately over $1k in material
All good thoughts - found a HVLP gun and figure with the compressor I should be good to go. And Don, I will spend a lot of time prepping and I am also a Simple Green cleaner guy. My hope though was that the dry ice blasting will do the yeoman's work for me and I will just be doing the last bit clean-up. I'll make sure to take pre-post photos. Thanks for all of the tips so far. This week will be peeling off the bitumen and disconnecting everything in preparation for lifting out that engine this weekend when I can get some help. Lots of photos will be taken to make sure it all goes back together correctly! I also very much appreciate the photos in Steve's thread since he has it all laid out so nicely.
The rattle cans work well for an engine bay because once everything is back in, you don't see a large percentage of it. A high quality mixed spray paint in a can with a good nozzle can lay down paint surprisingly well, unlike a hardware store can. Then a 2k clear will make it all purty, stain resistant, and hide small flaws. I thought about going the gun/compressor route as I have a 60 gallon one with plenty of CFM. I would certainly use it for exterior or large panels as Scott mentions but for under the hood I didn't want to mess with measuring paint, mixing, removing all water from the lines, cleaning everything etc etc for each coat. Not to mention the $$$$. If I ran out of paint or messed up like when I put the wrong honey comb fender insulation on, I'd just order a couple more cans from the supplier and redo it. They got to know me pretty well by the end of it.
Well, I think that this will end up being one of those circumstances where I can go easy or I can go hard and I may end up just taking the plunge. In another question, why are rubber engine mounts $100 per mount and also totally unavailable?
I was very please with the paint my local PPG shop had mixed up and put in a can. I got 3 cans and it was $58/per can Polaris same color my painter used to paint the rest of the car. Make a huge diffence and really easy to do.
color code was 32589 Polaris 60 And I love the high 5 priper
that's good to know - i was thinking of painting my lokari fender liners in ceylon. that could be a good way to do it.
Any thoughts on dropping the engine and transmission out the bottom with the subframe? I am considering doing that on my recently acquired 1972 E3 Bavaria to clean up and reseal the engine and transmission and rebuild the front suspension and steering. I have done it that way on a couple of 2002's and it worked great. It helps that i have a lift, but have done it without one as well.
Also Curious what the dry ice blasting is costing you. I asked for a quote at a shop here in N. Virginia and it was between$2K and $4K - Ouch!! Would also be interested in seeing before and after pics.
I don't have a lift that would make it easy so I think it's coming out the top.
The dry ice blasting is $1000 for underside, $500 for all wheel wells and $500 for engine bay. I will definitely take some pictures before and after. The primary motivation was the underside, since I spent an hour cleaning an inch of grime off the front driver side and it looked better but not great. From there the wheel wells seemed obvious and then the whole motivation for THIS thread was whether the work of removing the engine to get it cleaned and then me repainting was worth it. Clearly I've decided yes.
I'm jealous - when I emailed Lokari about getting some fenders they said they aren't shipping to the US these days. Makes sense and I think a lot of international suppliers are taking the same stance.
An update since I said I'd post after the dry ice blasting. I posted some photos in this thread:
Overall, I would highly recommend the process, and the local Seattle guy Dick Breakey who operates under the name Affordable Dry Ice Blasting was indeed affordable and did a great job. Since my car didn't have engine or transmission he was even able/willing to come pick it up with his car carrier and I arranged a tow back to my home.
At this point I figure since the underside is as clean as it's going to be I'll probably re-spray it with some rustproofing and then will prep/paint the engine bay and may decide to include the wheel wells once I get an idea how they look now.
  • Like
Reactions: Dlc
