WTB 3.45 differential for E3 Bavaria
Larry Louton
Venice Florida
Hello to all Sellers, Wish to purchase a good working 3.45 differential for my 1972 BMW Bavaria. Can be a open wheel or Locker. Have a business address to ship to. Strap to pallet. Reasonable price withe Zelle or PayPal.
Thank you
Larry Louton
Venice, Florida.
Thank you don, I took a picture of the Diff numbers for comparison to other diffs that are going to pop up due to Ai.
Larry Louton
I am trying to understand these three generations of sideloader differential.
Is the concern about the differential Don references due to the fact that it is a mid production case with 10 bolt ring gear internals with snap in flanges? Or that the ad says it fits models which used only a rear loader differential not sideloader?
The reason I am on this quest, is that my differential is long in the tooth as they say. I am going to pull it out for rebuilding. But I want to keep the coupe on the road and would like to get a second with matching generation and ideally internals so I can mix and match if needed.
I have a 3rd generation e24 lsd that was 3.07 and converted to 3.45. So it is a ten bolt ring gear with snap in flanges. I have been researching castings so I think I can identify third generation. My ideal part would be from a 633csi which would be 3.45 ideally lsd. I know how to identify the ratio, and whether lsd. I believe all with snap in flanges have the later ten bolt ring gear internals. If someone can confirm how to identify 3rd generation casting that would be helpful. Or any lead on parts appreciated. I understand this will not be cheap.
I believe all the Housing’s are the same for first , second and third generations.
And the first generation LSD units are tough ones to diagnose.
They are load dependent so simply turning the Wheels in the same direction and feeling for a lock up is not an indicator of LSD or not LSD.
My gear shop won’t rebuild those LSD units.
Second generation is the 8 bolt version with bolts that hold on the flanges, just like the first generation. My gear shop rebuilds those.
Third generation is ten bolt with snap on or clip on flanges.
Larry? $500 is a very reasonable price for the one on eBay.
Did you contact him and ask about the condition of the bearings?
Hello sfdon, I had a bad misunderstanding with your description of this ad. I understood Ad title is 3:45, Pic is 3:64 and Description is 3:91. If the prognosis is good, What is name and address of your diff shop for a inspection and estimate of needed repairs. Then I will be able to ship a good diff one way!!!
Thank you.
Larry Louton
That is what I want. Do you know what diff shop sfdon uses? That is where I want to send it to.
Thank you for looking in
Larry Louton
Pete has moved to Idaho.
Diffs are fairly expensive to inspect and rebuild. Bearings, seals, o ring and crush sleeve.
You can't inspect properly without disassembly. Once apart you need all new kit.
2 way shipping with plastic bins
250.00
rebuild
+-900.00
38 divided by 11 = 3.45454545455
Sorry you aren’t closer! I just took out my 3.45 open.
Swapped for LSD.
I imagine they are pricey to ship!
Hello Restart, So what are you going to do with the open 3:45? I have not yet committed to Riverside.
Thank you.
Larry Louton
Hello sfdon, I don’t like extortion or extreme taxation. Look at how Canada handled it. Instead of selling their products to the south. They went east and west and sold it there.
Larry Louton
Hello SFdon, I bought that 3:45 diff from Riverside and had it shipped to Venice, Fl.
Opened it up and found a centered pattern on the ring gear. The oil had been drained but what was left had no sparkle in it. Thank you very much for the good call and advice.
Larry Louton
