tdgray
So as it usually goes I was chasing a bunch of issues on the clutch… bad master… bad hose etc. I have those sorted out now with a 320 master and a universal hose. BTW if you change to the newer master cylinder beware that your lovely hose you just bought for the early slave will be about two inches too short.
Car shifts fine and operates fine when driving. Having an issue on taking off and reversing. I get a judder or shaking when taking off in first. Also as the car warms up the throw out bearing get noisy when I have it out of gear and no pedal depressed.
Any ideas where to look? I’ve looked at the clutch lever etc through the fork hole… all looks okay I guess?
