BMW Factory rebuilt ZF 4 HP 22 transmission with 26,000 miles For Sale
Ohmess
I wanna DRIVE!
Aiken, SC
I know, its not a coupe part, but hey, a lot of people here have multiple BMWs...
BMW Factory rebuilt ZF 4 HP 22 transmission with 26,000 miles on it recently removed from a 1987 535is. Invoice shows installation at Taylor BMW in 2011 at a cost of $5,143 when the car had 144,000 miles on it. Car now has 170,000 miles.
The transmission is an electronic controlled early E-7 version of the 4HP 22. This transmission was used in late 1980s 535s, 635s and 735s. Cars with this transmission will have a rotary dial on the shift console with three positions - S, E and 123. Ships with torque converter. $750 plus shipping.
That's a way better gearbox than the auto the E9 came with. You can use a stand alone transmission ECU from Compushift to dial in the shift points, shift pressure and torque converter lock up points. Massive improvement for those that want an auto.
I was not aware of Compushift. That sounds pretty cool.
Only for the electronic version of the 4hp. Needs a multi pin connector. Also need to connect to a throttle position sensor that you need to add. You can choose the shift point for every gear and how firm that shift is. You can also flip a switch and have a sport mode for higher performance with higher rpm shift points. Another switch will let you shift between gears like a Tiptronic gearbox. Very advanced. It's even better if you have a fuel injected car with modern ECU as the info sent to the Compushift is way more advanced.
Nice E28 535is! Looks like delphin grey.. the finish I had on my '85 Euro E24 M635Csi.
I used to own a white one of those with tan interior, and the M5 variant, black paint with tan interior.
