1974 gas tank removal suggestions
D Calkins
Royal Oak, Mi & Montgomery TX
The service manual shows the tank coming out through the trunk, however my tank bolts from below. I can only assume that earlier models came out this way. All three bolts have been removed but no luck. What am I missing?
All MY 74 are mounted from underneath, it is stuck to the sealing material which can also lead to rust. There should be five bolts, at least the early tank uses five, can’t imagine yours needing less.
My E3 came out through the top like this, Remove everything like you said and raise two foot up on hoist. Place 5 gallon bucket underneath the tank and lower vehicle onto bucket. When it is elevated about 6 inch's turn the tank counter clockwise. Hope you drained the tank.
Thank you.
Larry Louton
If the body has threaded holes then it can be fitted whichever way you like. You can even change it if you don't like your first choice, or change it every week just for the thrill. Just for my view though, I would go with the photo in the manual, then if any bolts come loose you won't lose your tank.
I don't have a bore scope, so I have no idea what the other side looks like. I sanded it down with a 60 grit pad on my DA sander so it looks less ugly. I treated the little bit of rust and dropped it off to be sandblasted and powder coated.
Completely agree, this type of tool is well worth the cost, it will pay for itself the first time you need to use it - find a nut that you dropped, look up above a frame member from below, look into a cylinder, etc
