9300111043900396165582
For those of you with oil pressure gadgets, are you running both the idiot and the VDO gauge?
I purchased this but I can't get the adapter screwed in far enough so the 1/8 NPt threads are pointed up so I can install the idiot light sender
Where did you get your dual sender?Had the same problem which is why I purchased a sender that could do both rather than having two senders.
I will ask Tim @ discount gauges what my options are.i bought the same sender as @e9Leveque from VDO, it doesn't require an adapter and has 2 connections for wires.
