BMW 2800cs -> S38b36 project
Received the Odyssey PC680 battery’s yesterday. Got some help/input from @Sven regarding the capacity of the battery’s. The battery’s fit in both directions, have enough clearance. Will make a battery holder to keep them in place.
Worked on the wiring last three weeks, and the relais holder from the left front location and were to relocate. I modified it to be attached to the firewall were normally the cooling water tank is placed.
Given the fact that the e34 M5 has a cooling waterflow regulator (incl. pump) for the interior radiator I also decided to go for a secondary pump on this project car. After some research done I decided to go for a Davies Craig pump. Received it today and modified the cooling water lines to make it fit. Need to order an additional 19mm connector but length is all arranged and it fits fine to the vacuum stuff bracket. I drilled a hole in the bracket to attach the pump to.
