1971 2800CSA: Turn Signals & Hazards not working
@sfdon believes my problem may be the wrong turn signal assembly for a Euro-spec car. I removed the steering column lower plastic cover and inspected the wiring bundle. While it all looks stock with no signs of being replaced or repaired, @sfdon says the wrong turn signal assembly may be the problem. I don't understand how this is possible as I would expect to see signs of a new turn signal assembly being installed. But as the Zen Master says, "We'll see."
My poor car has been rendered undriveable by little things since it arrived. Yes, it currently runs, but driving without turn signals is like driving without a seatbelt... not for me.
Catbert -- I understand you, here is a small anecdote for you:
When I bought my E9 in 2018 in Germany, I drove it home to Austria on its own wheels. Germany did not require seat belts for vintage cars, so I made the trip across the Autobahn (going up 90 mph) w/o any belts .... it felt strange, but I was so geared up by my "new car" that I forgot after a while about the missing belts and what could happen in case of hard breaking/accident a.s.o.
Fast forward a couple of years, post-restauration - whilst driving, my indicatior stopped working at one point. I fixed it later on when coming home, but with 50+ yrs old cars, things happen - always - not a question of if but when. I learned a great deal of resilience, patience and stamina over the last years, along with a "can-do" attitude.. as this is my first car I am working on
Been there man! And I know you want to take it for a drive since you've been waiting for it for a while, but take this opportunity to open the Pandora's box of other things that might need doing while you're waiting to figure this out...
Yes, I am. I have already addressed and fixed a number of nagging things (oil filter bits thrown out by mistake, hood torsion bar broken bracket housing, stripped threads on engine oil drain plug and differential fill plug, stripped threads on one brake bleeder screw, and cracked washer reservoir. Still on my "to do" list besides the turn signals are replacing one worn door stop, replacing missing door weather stripping, adjusting the valves, replacing the inline fuel filter, and figuring out how to wire the driving lights I installed on my new bumper. The green light switch below the two fuse buttons on the dash is wired to something, which I was told is for fog or driving lights. There are none other than what I installed. It would sure be convenient to use a switch already installed and wired.
I hear you and feel you. I'm not frustrated. I've been working on cars for many years. I'm just anxious and so looking forward to fixing the key items that prevent safe driving. I still have plenty to do with the car to keep busy as I just shared with @e9Leveque. :)
  • Like
Reactions: Dlc
Yes, the green switch is wired for fog light but I think that often is going to the rear for the rear red fog light. Rather than using that button and wiring it for the fronts, I removed my cigarette lighter and installed an E9 knob attached to a two-position switch. I have mine, like you, as somewhat of driving lights rather than fog lights so I wanted a way to have an easy on/off without having to reach under the steering column for the green button. Happy to send a pic of the end result.
Ah! That makes sense about the rear fog light. Now I know how to turn it off. Using the cigarette lighter switch for driving lights is a great idea. Yes, please post pic and where/how you mounted the relay.
What Dic said!
  • Like
Reactions: Dlc
Here are pics of my shifter console. In place of the cigarette lighter is a 2-position pull switch. This might be from a 2002, since I don’t think the e9 has any 2-position (off/on), only three position - lights, wiper, etc. I used the decals available from Mo Faraz here on the forum to identify wipers and lights.
This makes total sense, especially if those switches are often on the opposite sides from US to euro. Also All those wires that go up to those two switches could easily be interchange incorrectly and finally if for example Don had changed the switches, you would never know.they wouldn’t look like they had been replaced compared to some hack jobs. You might see
new paragraph
is that funny?
I'm coming late to this troubleshooting thread. One thought, IF the Green turn indicator lamp in the gauge cluster illuminates when the headlights (and marker lights) are turned on, you might have a feedback problem in one of the lamp housings. Try removing any dual filament bulbs. A shorted bulb can back feed the turn circuit. I suppose you could have a shorted lamp housing causing same, so a little time disconnecting and eliminating possibilities would be well spent. Much more pleasant than looking up under the dash. Headlamp and turn circuit have no overlap except in the bulbs, if we ignore a rare short (connection) between two wires.
I replaced all four headlight lamps to then install LED bulbs. All connections were clean, tight, and consistent, so I don't think there's any problem with the headlight fixtures and wiring. The previous owner who imported the car from Germany wasn't like me. He apparently didn't bother fixing all of the fix-it things I am coming across. For all I know, the turn signals weren't working when it arrived to the US. No paperwork, i.e., maintenance records or any records came with the car. The car is overall in really great condition with zero rust and a high quality paint job. So, I am left to get it sorted out. Being a car guy and a bit of a perfectionist, I first address things that don't work or don't work correctly.
You can install a purple switch that matches the others for the fog lamp
I was referring to the front marker lamps and rear lamps. US cars had dual filament bulbs (turn and running) in the front markers and EU cars use a single bulb (turn only).
Thinking maybe something funny went on if an EU car had US housings installed and the installer joined those two circuits.
Wow! Awesome! Thanks for pointing this out. I looked at the whole thread to see if anything about a newer hazard switch was addressed, but it didn't. Here are two pics showing my hazard switch and the one @sfdon sent me. It appears I would need to cut some of the wires on my relay to add more connection points. I'd rather not do that but don't know what wire goes where.
View attachment 229615View attachment 229616View attachment 229617View attachment 229618
Pre-facelift green foglight switches for EU E9s came with two spades to connect rear and optional front foglights, i.e. rear and front light would be switched on together.
Powered with parking light being on.
After-facelift switches came with one spade to connect the foglights.
The one on the left side of the steering column for the rear foglight only.
As an option a second switch could be installed on the right side of the steering column (at the precut hole) energising the (optional) foglight relay.
Foglight relay would not be energised when high beam is on
E9 switches came with the white ring.
E3 switches came without the ring.
Later types are not the srew type and would not fit.
...the CSLs came without the rear foglight, so no need for the switch
But since there was the standard hole on the left side of the steering column they put this dummy.
I found an orange three-prong switch on ebay and bought it. Then, I purchased a fused relay. Next, wire-up the driving lights!
