Upgrading from Dual Weber 32/36s to Triple 40 DCOEs – What else do I need?
I was talking with a guy that builds a lot of cars. Mostly big Detroit classics. He pointed out that the move to higher levels of ethanol will result is a greater propensity for vapor lock. His suggestion was to use a pump with an FPR and a fuel return line, like they do on EFI cars. Interesting thought.
Hey Mark;
What are those right angle trumpets you are showing in the pic attached to the quoted post (#42 of this thread)? I was thinking of doing that so I could mount air filters above them. Do you use that with an Alpina plenum, three separate filters, or a single giant filter?
There is a guy that @Stevehose put me in contact with who machines those right angle trumpets, and also makes a beautiful but huge billet air filter that covers all three carbs.
Hi, didn't see this till now,
those are from Mark in the UK, the Alpina repos, also bought the 'Alpina' plenum to go with
If you don't find him here on the forum let me know
with the Alpina plenum, there is a hose that goes over to a filter box on the inner fender
I will see if I have a photo of mine, but will look like Alpina
I think 1 or 3 filters on top of the 'horns' would be a good idea as well
The 'Alpina' plenum weighs a ton
If you do the remote air filter box, like the Alpina, you have to drill holes in the inner fender
Mark / Sven loaned me a part of the fender so I could drill the holes in the right spot, I returned it, so one of those 2 has it
