Upgrading from Dual Weber 32/36s to Triple 40 DCOEs – What else do I need?
My engine has all of the evap system removed,including the plastic tank and bracket in the trunk. That was only installed in the USA cars. Let me know if you need the mesh screens for your trumpets. Here's a pic of the screens next to the big brake booster.
That Korman manifold is a thing of beauty!
Thanks for confirming, Drew. How is you tank vented?
Will let you know on the screens, I'm not sure which ones I'll go with yet, but I do like this set I found on Weberjets.com they are a lower profile, flat on the front. Unfortunately they'll charge 40% tariff to get them over the Canadian border from Vancouver to Seattle. Not sure I can stomach this out of principle.
The gas tank is vented by running the hose to the hole in the bottom of the trunk that has a funnel shaped grommet. I don't have the BMW part # for the grommet handy. All of the European cars vent the tank with the hose to the grommet.
Easy enough, thanks again. Can't wait to dig into this conversation.
Whats the general consensus on base gaskets? Soft mount rubbers or regular fiber/paper ones?
I’d like to hear the consensus about this, too. I used the soft on my 02, but the big 6 is much smoother running, and I’ve heard they don’t require the soft mounts..‍
I should say that my plan is to use the fiber/paper type as Stevehose has done but after arguing with Claude, who was in favor of the soft mount, I figured I'd seek a resolution here instead.
Has Claude ever tuned triple Webers on a coupe?? Steve Armstrong (hose) has done more work on DCOE Webers than probably anyone on the forum. But I must say that my Weber setup on the Korman intake manifold has the soft mounts with the Weber designed spring washers and it has run w/o problems for 7 years and 25K miles.
Haha well it pretends it has, which I why I called BS and came back to the real experts.
OK folks. Now that @D Calkins has raised the question of vacuum for the booster, I have been researching options. I made my new manifolds without any vacuum ports, and figured I could easily add them if necessary. I found some nice miniature nickel plated barb fittings for lab use, and was thinking I might simply drill and tap holes in the tops of each manifold tube, and gang those together into a plenum to fee the booster.
However, I am wary of any setup that might disturb the individual carbs. If I gang vacuum between all of the manifold barrels, then technically I will be changing the vacuum behavior of each cylinder intake runner in odd ways, since the other cylinders will be affecting any given cylinder intake. I suppose I could route the vacuum from each runner through a check valve and then into a plenum, but that's going to get awfully complicated and busy with six separate vacuum lines.
I read one earlier post on this thread that one person was using just the vacuum from #6 (which is how the Karzundpartz/Pierce) manifolds are set up), and he said it was basically useless. In addition, I will be running atii booster, which already has somewhat less power than the original, so that combined with limited vacuum sounds like a recipe for poor braking.
Has anyone used an electric vacuum pump for the booster? These seem fairly simple, and effective.
you can PM me or call, I live in Kirkland
Hey Mark;
What are those right angle trumpets you are showing in the pic attached to the quoted post (#42 of this thread)? I was thinking of doing that so I could mount air filters above them. Do you use that with an Alpina plenum, three separate filters, or a single giant filter?
There is a guy that @Stevehose put me in contact with who machines those right angle trumpets, and also makes a beautiful but huge billet air filter that covers all three carbs.
The Korman intake manifold has barbs underneath the manifold at cylinders 2 and 5. (If you add barbs, I recommend putting them underneath the manifold as I think it will look better.) I've combined these, then put a check valve in line, and then connected to a tii booster on my car. For braking, this works well. I've not really looked into the potential disruption in airflow and/or performance, but Korman was pretty good with BMW engines and I presume he thought about this.
Does anyone have any recommendations for wiring up and placement of a fuel pump controller and relay? I decided to go with a Revolution Electronics controller and an thinking of hiding it under the dash, but have also seen installs with it mounted to the front drivers fender wall or in the trunk. A wiring diagram would also be helpful if available.
