steve in reno
How do you align the doors on a coupe?
Has anyone used generic contour seals from non-BMW cars?
steve
steve
Bill Riblett said:here is what I do:
Remove the door upholstery panel.
I also remove the front seats for working room.
Shut the door.
Loosen the 3 bolts inside the door for the hinges.
Shut the door.
The bolts are as you describe and I think have always used Allen wrenches. However, I have gotten a bunch of Torx in recent years and may have used them the last time a couple of years ago. I don't know what BMW used!jmackro said:Bill:
I need to adjust my gaps, not the "flushness" of the door panels with the body panels. So, can you clarify two things:
- You are referring to the bolts that attach the door to the hinges, not the hinge-to-body, right? When these bolts are loosened, is there some play? That is, are the holes in the hinges oversized, or are the nuts floating? Or, do I need to add/subtract shims where the hinge attaches to the body to adjust the gaps?
- The two back bolts on my hinge-door are standard 13mm hex head, but the front/top one is some weird 12 pointed allen. Is this a Torx? Anyone know the type and size of driver that will fit it?
Thanks!
Thanks!
Nope.Are they the same special bolt as in the brake calipers?
Thank you very much for that informative reply. Although I must question the part where you hypothesize that a socket is too large to fit in there. The hole in the door frame is much bigger there than it is in some areas where you are supposed to get a socket in for the trim. But no matter.It's an M8 triple square from memory, I guess they are like that due to a socket being too large to fit inside the opening.
Note that a triple square whilst outwardly similar is not the same as a 12 point bit as the angles are slightly different
