1971 2800CSA: Turn Signals & Hazards not working
Ok, let’s start from the beginning. Been there! Did you at any point have working signals and now they don’t work, or have they not worked since you got the car? Is it both sides that don’t eork? When you push the turn signal stalk (which in my car is the RIGHT one, which is different than every other car I’ve owned), there’s a turn signal light that lights up on the center gauge - does yours do that? Did you check the bulbs? You care most about the turn signals - having a functioning hazard button isn’t critical, but its wiring is part of the circuitry.
The center dash green light comes on when the headlights are turned on. It does not when I push the turn signal lever up or down. I haven't checked the taillight bulbs yet but will.
start with checking the grounds and whether you have working bulbs. always the best place to start. the front turn signals are grounded behind the fixture, same place that the headlights are grounded. the tail lights are grounded in 2 places. the wire hooks to the make spade on the fixture housing and then connects to the body.
if grounds and bulbs are working, what happens when you hit the 4 way flasher? early on i had turn signal issues and by swapping the 4 way flasher, everything worked great.
What do you mean when you say the turn signal is grounded behind the fixture? What are you referring to when you say 'fixture'? Also, by '4-way flasher' are you referring to the hazard switch? As already stated, I tried connecting a new haz switch and turn signal relay, so those are ruled out.
Good point, although I think you're finding that this isn't a Timex with it's "Takes a licking and keeps on ticking". It's more of a beautiful old grandfather clock, attracts a lot of attention, very unique, but needs to be wound a few times a day and is always a few minutes off. Having had one of those in my home growing up courtesy of my Swiss mother, let's say that she definitely knew "how the watch worked"!
I meant going through the effort to learn electrical troubleshooting skills which is a long road and "learning how a watch works" vs. telling time. To do that means going back to basics and learning what basic electrical terminology means. I just want to fix my car, not to back to college. :cool:
Fuse 5 is Hazard circuit which gets power (red wire) direct from battery, Fuse 8 is Turn Signals which gets power (green wire) from Ignition Switch in Run position. Start there.
The very first thing I did was to check the fuses and the connections to the relay. All are OK. I found no loose or broken wires, but I realize that can be deceiving.
Open the headlight cover and shine a light down in there. The turn signal has a ground wire that connects onto a small screw on a metal offset. By fixture we mean “the actual light part” not the lens - where the wires attach. It would be weird to have both signals not be grounded but weirder things have happened and it’s always a good place to start. In the end the most painful thing might be the easiest, which is to have one turn signal loose from its attachment to the car so that you can easily access the connections on the backside and then see whether you are getting power to it. I’m with you on the electrical part, I have to relearn parts of the ways of testing every so often, but it is a critical skill so may as well take this “opportunity” that has presented itself. You can do it! Soon you’ll be wiring in relays and running new cabling!
I just want to say that while addressing problems and things that don't work on our favorite classic car can be aggravating and frustrating, it's uplifting to receive support from so many good people.
the fixture is the entire turn signal light body that fits on the fender and has the amber lens on it.
the fixture has 2 or 3 wires to it depending on whether it is a USA model (3 wires - turn signal, parking light + ground) and the Euro model (2 wires - turn signal + ground). the ground for the ground wire attaches to the body behind the hood grille, right near where the fixture mounts.
yes, 4-way flasher is the hazard flasher - different than the hazard switch
By flasher do you mean the relay? @sfdon already sent me a new relay and haz switch, neither of which worked.
there is a hazard switch (#51) and a hazard flasher (#42). when you look at the wiring diagram, the turn signal switch (#56) connects to the flasher (#42)
the blue / red (left side signals) connects the turn signal switch to the hazard switch. there is also a blue / black (right side) that connects the turn signal switch and the hazard switch. the green / yellow connects the flasher to the turn signal switch, from the switch the green yellow also connects to the flasher. there is also a green / violet wire that connects the flasher and the hazard switch. the other wires are power, ground and signal to indicator lights.
Where is the hazard flasher located... in the hood release fuse area?
Depending on what you mean by the centre green light on the dash This could be a major clue for you
There's a green light between the tach and speedo gauges. It comes on when the headlights are on. I presume it blinks when the turn signals are engaged.
Keep in mind that you have a late model car from Europe and a US turn stock will not work from an early car
There is a photo here, Hazard and Turn Signal. Mounted to left side of steering column. Green light is turn signal and flasher only, never on with headlights.
