2800 Auto, 10 years WAITING started the work to get her back on the road
200272
UK
Hi I hve been lurking for the same amount of years as I have stored the car.
It’s moved homes 5 times.
I got her running with some good advice, it was fun ragging around the woods near the old barn with no brakes nd exhaust :D
Drivers side jacked up on axle stands in I got to work chopping.
She’s never going to be a minter, I’m going for the wolf in sheep’s clothing.
I’ve had the steel panels for yonks it’s nice to actually get them fitted.
Cute Morris! That was my first car! 1957 Minor 1000 Convertible!
Good luck on your project!
Thanks, that’s my daily work van. That Christmas I fitted a 2L zetec into her.
One of many projects that delayed the E9.
I had started dismantling the drivers side back in 2019 and did not get far, just the outer sill and front and rear wings cut, plans were made nd then I got a 2000CA
Late October I finally got stuck in.
Door removed and a brace fitted.
Then on the Sunday I got the rest done.
I’m trying Epoxy with Rust converter in the same spray can on all the inner sections, I then primed and top coated in black.
All the plug weld holes were marked up and ground back to bright metal.
The Inner sill needed a small section at the front with a small section on the floor too, the intermediate sill was surprisingly good so I just let in some 2mm steel and zapped it up.
The walloth sill has spot rust due to the many years of waiting patiently.
With the inside coated in Miparox (the epoxy rust conver stuff) I got to the slow process of fitting the Walloth wing repair panels keeping the heat down by going through and organising the many parts I’ve collected for this car, in between the welds.
New bushes, billie shocks n springs.
Powder coated spare rear axle and rear trailing arms.
She will be going manual, I’ve a box and pedals to mess with.
Early November I’m now looking and firing her up to turn her around and attack the passenger side.
