Ulrich 3.0 CSA
Hello all,
I may have a problem with the correct mounting of one of my starter lid of my 3.0 CS
problem was: one of the starter lid was loose (No 12 in drawing). So I removed it and checked it. The spring was Ok also it is electrical Ok.
I than mounted it again. BMW manual doesn´t say exactly how to mount it. You can put the driving dog arm (Pos17) in different positions while connecting it with the spring.
I tried it in different ways. If car is cold both starter flaps are mooving smooth from closed to maximum opened (if actuated by hand)
But after car was started and cooled down the starter flap of the one carburator doesn´t move to "fully closed " position- there is a resistance maybe 10 mm before "fully closed" position
Car will start and idle in automatic idle position. After I pushed the accelerator pedal it will idle at correct RPM.
Does someone know how to mount the starter lid 100% correct to the Zenith Inat carburetor?
Thanks Ulrich
Thanks Ulrich
