I have some answers. The valve cover is needed because the bolt hole in the upper timing cover is in a different position. The motronic distributor, and the way it is mounted, is completely different from the original (hence the need for a different upper timing cover, and valve cover). The fuel pump option that I used is a two pump set up. One pre-pump in the tank (part of a 320i pump/sender unit that fits in the existing tank hole) and a separate main pump. The 320i sender unit is about 10 cm too short, so I had to lengthen the pump to reach the bottom of the tank. The sender will read empty with still 3-4 gal. of fuel remaining. I believe you need just 4 sensors. O2, coolant temp, manifold air temp, and timing (VR sensor mounted on lower timing cover, reading the toothed harmonic balancer wheel).
Oh - forgot the throttle position sensor. I think the D-Jet sensor is either open or closed. The motronic needs a variable reading from 0-100%
