3.0cs brake booster
Yes, Greg, the booster should work the same as on a 3.0CS. The bracket that the booster mounts to is the same on both cars, so mounting it is not a problem. After you disconnect your old booster from the brake pedal and the booster bracket in the engine bay, be sure to measure the length of the rod that attaches to the pedal from the back face of the booster itself to the fork on the brake pedal side. You can then adjust our rod to match that length before you install it. Because the tii booster is longer, you will need to bend the five brake lines that attach to the master cylinder to match those connection points.
We've got company right now but I'll try to call later this weekend.
Hal
Many thanks Hal! and looking forward to speaking. It is the length of the brake lines that I am concerned with and hoping to not have to replace them. Appreciate the quick response via the forum!
Best regards,
Greg
