3.0CS on eBay
teahead
aka "Rob"
Tacoma, WA, USA
No trunk pics either. Sunroof or no sunroof?
Some people (actually few people) really know how to sell a car on the internet.
I've sold maybe 10 cars on ebay and I have at least 30 pics of everything at every angle with a LONG description w/bullets, PROs/CONs, etc.
However, this E9 does look pretty dang good. I predict at least $50k.
Eiremon
Boston, Massachusetts
You can see the outline of the sunroof in the photos. It won't come close to $50k unless the seller can provide more details / photos.
I am curious about the engine - it looks like it has some form of FI upgrade. Perhaps it's also a 3.5?
teahead
aka "Rob"
Tacoma, WA, USA
Hmmm, look at the air intake to the TB, no AFM. I thought it was D-jet not 3.5.
Twin turbo?
Markos
Seattle, WA
Assuming the ad is legit the car should fetch at least $50K. There have been numerous articles on the car. The pics were scraped from this photo shoot. Perhaps you found yourself a car...
http://www.fantasyjunction.com/cars/1370-BMW-3.0 CS Coupe-3.0 Litre Twin-Turbo 6-Cylinder
Yup, same kit
https://drive-my.com/en/social/stream/item/5122.html
The story starts back in 1994 when a technician at BMW specialist Moran Motorsport in Berkeley, California took a well-worn 3.0 CS into the company workshops and prepped it for a respray. Typically, rustprone E9s fare far better in California’s hotter climate than they do over here in northern Europe, but the bodywork still needed plenty of attention and the Moran technician decided he wasn’t going to go for half measures: his tired project was completely stripped bare, with all the suspension, interior, glass, doors, wiring and powertrain removed before the bodywork was bare-metalled in preparation for its fresh coat of gleaming white paint.
It was a labour of love for the technician, and he spent the next decade working his way over the E9 during his spare time until he was finally happy. The original 3.0 CSs came with a 3.0-litre, carburettor-fed straight-six but this car’s original engine was ditched during the project’s reassembly phase in favour of a 3.0-litre, fuel-injected M30 lump from a 1977 530i, which was uprated and fitted with the twin turbochargers. It’s a compact and neat installation that could easily be mistaken for a factory job and it’s tough to see the turbos when you open the bonnet, even if you do trace the two pipes that arc over the rocker cover and down into the engine bay’s depths. In fact, it’s only by getting on your knees and looking under the car that you can actually see the small turbos that are stamped with IHI logos. They feed directly from a Pfaff manifold straight back to the inlet manifold without passing through an intercooler on the way.
At the same time as the new engine was fitted, in went a more modern five-speed ZF manual gearbox to replace the original four-speed unit, plus a heavyduty clutch, limited-slip differential and beefed-up suspension, which included chunkier anti-roll bars. It took another decade for the interior to get any attention but in 2004 the leather seats, carpets, wood, dashboard, headlining and door panels were all either replaced or restored to their former glory, and today the interior still looks fantastic. Most recently, in 2008, the turbos were rebuilt and a new stainless steel exhaust fitted, as well as a highflow K&N air filter, upgraded fuel pressure regulator and blow-off valve.
CONTACT:
Fantasy Junction
Web: www.fantasyjunction.com
Tel: +1 510 653 7555
Those rear tyres hook up and feel perfectly capable of putting whatever you throw at them down to the surface.
Interior took ten years to restore and it’s beautifully finished. A modern stereo and window winders are the only additions.
Engine bay looks relatively standard aside from the extra pipework as the turbos are located low down. They certainly do the job though.
This turbocharged 3.0-litre #M30 is very refined, with none of the uncouthness you might expect from an aftermarket conversion.
VIN Code 2250293
Exterior Color – White elephant
Interior Color Black Leather
Mileage 2497 Miles
Engine #M30B30 3.0 Litre Twin-Turbo 6-Cylinder
Transmission 5-Speed #ZF
Stock FJ1417
Eiremon
Yes, this does appear to be the same car as the FJ listing.
http://fantasyjunction.com/cars/1370-BMW-3.0 CS Coupe-3.0 Litre Twin-Turbo 6-Cylinder
"It is worth noting that there is a vibration that appears to be in the driveline and can be noted in a narrow speed range around 30mph. It is not detectable at low speeds and disappears once the car’s speed increases."
More info on the turbos:
http://www.e9coupe.com/forum/threads/twin-turbos-for-e9-sold.22764/#post-166750
Stage 1 delivers a 50% power increase, Stage 3 goes up to 300%.
Given the modifications on the car the seller better be able to provide A LOT more information beyond the current listing.
Originally listed at $68,500 in 2013. Price was reduced to below $50k before sale.
http://web.archive.org/web/20130616164322/http://fantasyjunction.com/cars/1370-BMW-3.0 CS Coupe-3.0 Litre Twin-Turbo 6-Cylinder?
Sold prior to April 2014.
Eiremon
Note the modified air intake. The original turbo kit had the air intake next to the engine. Modified to pull cold air from the front of the car.
