L
Lostagn
Guest
Hi
First post here.
Took a while but managed to pick up a CS with 90% of
the body restored.(motor gone).
Then got lucky and got a 1991 M5 (rear end hit).
I have looked around a bit here and have found a lot of info here
on this swap.
First question I have is with the rear end.
Should I upgrade it to a newer unit ?
I thought I read some where that a 1985 535i
suspension will partially bolt in then some retrofit required ?
I want to start with this so I can figure out which trans to use.
with or with out speedo gear.
thanks ahead of time for any advice.
First post here.
on this swap.
