Early stages of bringing a new-to-me 1972 3.0CS vin 2240100 back to life, last titled in 1995. It is a real mess.
Initial list:
Alternator: Battery was hooked up backwards (positive ground) by PO. I've removed toasted voltage regulator, burnt harness, and alternator. Ordered an AL45x from bnrparts (thanks to this forum, great guys, knowledgable) Internally regulated 80 (or 85?) amp version. BNR is including a wiring skecth. Ive also ordered, but not yet received a schematic from ebay. Replaced battety cables +/-. I'm considering getting the schematic tatoo'd to my forehead... A check for shorts says my problem(s) are not limited to alt and reg. Will dig into the short(s) when schematic arrives.
Fuel tank: leak at front edge of seem.
Power Steering pump: screaming
Front Wheel Bearings: 3/8 " play at spindle. So bad, im expecting, but not yet confirmed the spindles may be scored and ruined.
Brake fluid resevouir: empty, but brakes are solid. Suspect clutch slave cylinder.
Drivers side window: stuck 4" down. Switch wiring frankensteiened big time.
Missing: air cleaner housing, replaced by cheap aftermarket filters.
Misc wires disconnected in engine bay
Throttle linkage (weber carbs) is worn, needs replacement linkage joints. Good source? Mcmaster ?
Head: has a "73" forging stamp om the side, near the front. Has this head been replaced? How can i chase down/interpret forge casting numbers?
Much more to come. Thank you (Steve) and all for comments and suggestions.
Tom
Marblehead, Massachusetts
Initial list:
Tom
