I've searched this forum but haven't found much in the way of detailed installation instructions. Has anyone successfully replaced their weatherstripping? Thanks.
Thanks Dave, I found the thread and although a Golde roof was used in both models, the installation procedure is different because the coupe seal is mounted to the sliding roof, whereas the '02 seal is mounted to the opening.
Is the rear seal installed with the roof in the closed position? That seems to be the only way because it gets tucked under the roof as soon as you begin to slide the sunroof open?
