nathanegger
Hi. I’m looking for a pair. Complete with mount and motor. My car has installed since new but missing those parts yet. Thanks
That is the same set i mentioned earlier - for around 1100 EUR.FYI - There is a set for sale in Germany:
https://www.ebay-kleinanzeigen.de/s...-3-3-e9-csi-e12-e21-alpina/824646205-223-6710
Nope, wiper blades are little bit curved & have long/wide rubber surface, so they will fit good for Bosch or Hella standard headlampsRelated but separate topic as I've been following and commenting on the "which headlamps to buy for an e9" thread. The really cool and tragically rare headlamp wiper option would seem to require flat lensed headlamps, yes? Which is to say, the domed units would not be suitable for wiping?
Understood, and thank you. But what are the headlamps in the @lloyd post above? They look flat(ish) to me. At least when compared to high domed lights. I could be projecting...Nope, wiper blades are little bit curved & have long/wide rubber surface, so they will fit good for Bosch or Hella standard headlamps
But you are right - to wipe 100% (not 80%) efficiently, surface of headlamps should be flat.
There was no flat headlamp lenses for E3, E9, E12, E21, E23, E24, E28, E30.
Yep, these are the lights I have. I guess my description of them being "flat" is slightly exaggerated. I've always considered these flat in relation to "normal" headlamps. Thank you for the confirmation.They are “almost flat” Very flat. If you go to www.rallylights.com they have the lense profile for H1’s.
Here you can see shape of wiper blade. Lamp is standard E9 HellaYep, these are the lights I have. I guess my description of them being "flat" is slightly exaggerated. I've always considered these flat in relation to "normal" headlamps. Thank you for the confirmation.
Yes, sure. Do it, don't ask MarkGood info! Would you mind if you or I added this to the consolidated notes thread?
By the way, what is "the consolidated notes" thread?
