• Tapatalk is being removed immediately. There are security issues and there is no justification for having it anymore. I apolgize to those die-hard Tapatalk users but you'll need to start using the forums mobile version instead.
88 3.5 COMES OUT
Mot27cars
Elkhart, IN
1988 735i engine removal.
The rest of the car is there if anyone needs anything.
HB Chris
Huntington Beach, CA
Since the coupe is a keeper I decided to look inside, just needed a hone with new rings and bearings are cheap so did them too, plus both chains and gears. Had head checked and put in new valve stem seals. And I added a cam.
HB Chris
How do piston tops look, oily or crusty? If not leave alone but throw in new bearings and perhaps chains/sprockets depending on how they look. I can spend other people's money easily!
dang
Administrator
Staff member
Rocklin, CA
I got my M30B35 from @Mike Goble and he had checked good compression. These M30's are so "bullet proof" that I decided that was good enough and just dropped it in after valve cover and pan off. I'm not worried. :)
