To occupy my time while my head is being worked on I installed a solenoid that will bump the idle speed when the a/c compressor cycles on. I was going to use vacuum advance but 61Porsche sent a link from another forum with the electric solenoid.
It's an ES-44 model and cost $25, I fabricated and painted black a bracket for it:
Then I ground down an old linkage ball flat on one side, this mounts in a hole on the accel linkage plate on the block:
Also added a separate ground wire and mounted it to the bracket:
Installed it to the block (there are 2 unused threaded holes on the block perfect for this, I used the lower one and angled it up towards the ball to line up with the action of the throttle:
I grounded it to the oil filter plate and wired the positive behind the firewall insulation and tapped into the a/c compressor wire. Final install is not very noticeable.
The solenoid is adjustable so when I get my engine running I will fine tune the positioning and idle rpm bump. So far it looks like it will work and will update in due course.
