AC faceplate refinishing
climbernyc
Bedford
I managed to find an uncut radio faceplate. However, the surface is pitted. Has to be bead blasted - what would you suggest is the best method to replicate the factory finish? Powdercoat? A type of paint or method?
Many thanks!
Markos
Seattle, WA
I've been using a truck bed spray paint but it is a bit too textured. I think Alan recommended using a tooth brush to splatter on extra paint after you have your base coat. I will be experimenting soon with my final revision of the :D printed plate. I'll probably paint it in a few weeks.
This is the rustoleum truck bed rattle can..
looks like a satin slightly splatter. SEM makes great satin, perhaps over something that gives the texture.
AOenmq6kfFImi_mY88aPvFb5_yFj8s6veMth6GSgaSupvg7JLGKHEN7N6027khJ2Kwn8zacmt8plhnP0LU8dGCvjslt4apypMUfunvj4aY6aeGP03FPH1DEU54hLDm2RwEsJGQ5cLm9uNeFCsmq77gqdiEfhF83ColTWLfhdI8UtD1GoJpbFuebCWwxpvQjvu07ph7EAduKC4j7Jf3b7qma6RmBw66QbbwURKy4FBKJeX0wFSlARAWwBAvGU21d2qwSvv-1QYsWCqlWwkRYaE9EOYobcTMXh6ietvj62xrj_eMrD7w_ktA3JZNqP8epRwpKeqH5V5gwEwH7y5BhuvYoixnxkeAAOeLZxpPN-0jTyHPHx8Kk-UahspEwWE2C57jnk--SF8qs0fAvGt6ZKMGoDkynLL97kWVo6YP7B7rj-1KG1qHa32T5b_qXlsUsha5-sVbJ5aywbJNs7uRmaIn3X3rRmgMpoc7HKfLF6kFcWcwS-spD0oqdQK6ahSuhGqU9uMIfAyxT7LnIrncb5OhFvUuzqoJt4Y73jGREhb0XikBhwuteoxNtvqQJ5ZBHRKw-AHnmUSnSz4KlD7Lmb1kfuA5obUpYV0BfyQ71Y_1v4t1YkG_Z6=w1028-h771-no
climbernyc
Bedford
This is the existing along with nasty shift knob that must be glued on with epoxy!
Maybe if you sanded it down a little before top coating it would flatten out some and still keep a just a little texture?
Markos
Seattle, WA
It almost looks like "hammered" paint. so may try that next.
Edit: If you look at my second iteration of the 3D face plate, it is in fact hammered paint. Still a bit too much oarange peel IMO.
