Aircon temperature control broken
TomHom
Germany
The ceramic mount of the potentiometer is broken. Applying super glue will surely not last long. 20240924_230521.jpg20240924_230528.jpg20240924_230458.jpg
Any idea for repair or replacement?
Thomas
Quick search reveals some potential problems with dried superglue - possibly flammability and release of toxic substances!
Ceramic is holder/insulator for (hot!) wound resistor wire. Wouldn't use super glue due to heat but applying a modern high heat epoxy coating that would lend structural strength should add a few years. Hollow rivets might allow mounting a backing plate - sounds like a project for someone.
They haven't been made for a while but that never stopped me before. :)
Doesn't look like there is a provision for powering up the thermostat (or relay depending on year - 5th pin?)
Don't see a wire
You are right, it's missing.
I'm just starting to understand the function:
Is there a circuit diagram available?
The single black wire powers the thermostatic switch that turns on the compressor.
Two versions- early and late.
I bought 6 from a dealership in Egypt that was liquidating their inventory.
