Farzad Arjmand
Hi , is there an alternative oil filter that I can install so the oil change doesn't become so messy ....
			Thank youDepending on whether or not your oil filter has a check valve in the filter body you will want a filter similarly equipped. The top-bolt filters came with and without check valves.
Pictures in this post:
I have a few of the top-bolt filters in my shed.Thank you
Although I use top bolt filters, it may be worth noting that there are spin on filter adapters, too.Yes, you can use a top bolt filter housing from the M30b35 engine.
Ireland's threaded adapter bushing shown, is for a 4" canister as can be noted by the two different thread sizes. I may still have one that will work with a 3.5" bottom bolted canAlthough I use top bolt filters, it may be worth noting that there are spin on filter adapters, too.
https://e9coupe.com/forum/threads/spin-on-oil-filter-adapters.36940/
Another example can be found here >> https://www.iemotorsport.com/product/oil-filter-adapter-spin-on-type-m30-e9-e12/
Thank you will try itYes, you can use a top bolt filter housing from the Kool Katz Auto glassengine.
