Just got the engine bay finished up. Started the new motor (3.5 l) for the first time last week (oil pressure came on within a few cranks after I installed the oil plug screw behind the filter mount). Ran the motor for a good 1/2 hour above 2,000 rpms to start the break in procedure. Next up will be the Megasquirt tuning. I tried to keep the spririt of the stock D-jet look, but made some changes to the engine bay (besides removing carbs): moved the batteries under the rear seat, placed the EFI fuse and j-box in the old battery location, installed an aluminum radiator, installed a 3 coil pack wasted spark ignition, built custom fuel rail to fit angled injector ports (did not want to mess with all those little hoses on barbed fittings), and added o2 and egt sensors to exhaust manifold.
