Another ignition switch expires
bluecoupe30!
After 53 years, it is time to replace my ignition switch. After reading all the posts here, and researching part numbers, I found the go-to replacement switches have disappeared. The fix now is to install one from an E12, E24. SFDon suggested I call Carl, and I now have my new switch, part number 61321366107.
Extra wires on the new one. I see the common Red, Black, Violet and Green ones, but there is also thinner brown, brown/blue, and brown/yellow.
So, anyone used this switch and can tell me what to do with the brown, brown/blue and brown/yellow wires?
Also puzzling, my original switch has a short length of grey wire from a terminal on the back of my ignition switch. This plugs directly into a stalk on my steering column. New switch does not have this. Any ideas?
Oh, and if you haven't ever replaced your ignition switch, I suggest you at least acquire one to have on a shelf before even this part number becomes NLA.
Thanks for your input. Mike
some photos: New 61321366107, my original, nice shot of never-been-messed-with and painted red, grub screw. Came out easy!
that part number is for an e12 and e24 - it also superceded the part for the e3. the original part was xxx147. the original e9 part was xxx148. probably some very minor differences. 148 is definitely NLA according to getbmwparts.com, the xxx701 part is currently unavailable.
Hoarding, yes it's a thing! I did find this short grey wire plugs into a connector that is part of the loom that goes to the turn signal/wipe wash stalk. I can see the grey wire soldered to the back of this switch. I wonder if this is power to the switch or what? Somehow, the wipe/wash turn signal switch connects to ignition switch this way. Hmmm
i just traded emails with Carl - the 701 switches are gone. i think the switch in the pic is the 107 switch which Carl says has a couple of extra wires
Yes, you are correct, Scott. I entered the wrong p/n above. (edited now) I did in fact receive 61321366107 from Carl. I tried everywhere for ..701, but truly NLA. The ...107 is the next one up. It comes with a plastic case. The metal ones, as per original, now only available on eBay for $$$$. Yes, extra wires. So, perhaps they are just not needed?
Keep the yellow/brown wire- that is your horn wire
Cut off the other 2 small gauge wires at the switch
I'm still a little confused after reading five or six different threads on the ignition switch. Maybe someone can help me here.
There appear to be two different electrical switch parts. But some of the descriptions look as if the wire length is different but then another thread said something about it not matching as the locator pin is at 90 degrees and 120 degrees for the different switches. Or was that some kind of speculation?
So which one is this part number 61321366107 replacing? Or do I just have myself thoroughly confused with too many ignition threads.
I was confused as well. it seems the only switch available now, has its locator peg at 90 degrees to grub screw mount. The switch that came out of my car has this peg at about 120 degrees. So, the peg has to be removed from the replacement switch to allow it to fully enter the barrel and get secured by the grub screw.
Aha... okay. If this is what it is then we will all work with it.
Think I will go ahead and order it to "get in" before everyone here hoards these too :p
So today I fitted the new switch as per our discussion.
It's definitely not straightforward plug and play as we all had discussed.
First, in my case and who knows if this is just my 2800CS or an early late thing... Couldn't tell ya... The little nub for locating and I'm sure for rotational issues has to be ground off. It indeed is in the wrong position. That's easy
Next after a few test fits... I had to grind some of the black casing in order for it to fit around the metal structure of the column. I shaved a little here and there around the two places.
Having cleared those I found that it would "almost" go in. I had to relieve a bit more of the casing on the bottom in order for it to slide in all the way so that the grub screw could go in hole in the housing.
I did test the rotation. Turns just fine. Definitely more feel... Resistance than the original. I am a little concerned that it's just one little piece of plastic holding it from rotating but we shall see how it holds up.
You can see in one picture how it was not sitting down far enough in the barrel. The other are where I was relieving the black casing ... Careful not to grind off the tabs holding it together and then the final fit.
I was doing all of this.. well because it needed done but also because I have been working on my wiring harness for the last week. After test fitting... I plugged it in the fuse box... The final fitting of the switch and grub screw will have to wait until the car is being assembled.
Oh yah... They wire connectors come bare. I used some heat shrink tubing for covers... Don't like bare wires back there.
  • Like
Reactions: Dlc
Well I have circled back to this repair now as my back is feeling normal again. Apparently it is not a good idea to use the rocker panel as a fulcrum for your back as you lower your shoulders into the driver side footwell and reach up and around the fuse box to see where all the ignition switch wires attach. As noted above from Todd, it is a fussy job shaving/filing/sanding the outer plastic casing of this part number. It just will not go all the way into the ignition barrel. I spoke with Carl and he suggested "relieving" some of the aluminum in the steering column over sanding any of the plastic casing, but in the end, I did a bit of both. Sorta had to "hone" the inside of the barrel where the switch needs to fit, as well as trimmed a bit of the black outer rim of the switch.
To get the final fit, I shaved a bit from the "nose" of the switch that fits into the opening in the barrel of the assembly.
Then it all seemed to fit. I made an attempt to fit the grub screw, and in it went. A perfect alignment! Whew! What a pain, but happy it is secure. Still have days of wiring ahead of me as I did not like what I saw in there. Cannot un-see it. ;) So, I will spend some time organizing, reconnecting some suspect connections, and hoping everything will work again once completed.
Job is doable, but opens a can of worms as many of these can. And difficult to avoid the "while I am in here" great ideas. But as I have said before, get this switch in your inventory before even this one is NLA. Mike
Story time. Many years ago I was temporarily stranded on the North Shore of Oahu when the key for my '64 Bug went missing. I did have my trust Clymer manual wiring diagrams so I sussed out the function of the ignition switch and connected one wire to power the ignition and grounded another to run the starter. Drove this way for several months. Another time the key for my '67 Squareback went wandered off. I used a toggle switch cockroached from an abandoned Bus, plus a nice chrome pushbutton momentary switch from the local boat dealer. Alles gut, until some kids tried to steal the Squareback. They ran off when a pal went back to the car for his towel, and left their surfboard strapped to my roof racks. Obviously meant to have the board, we tootled off, I fixed it up the gift board and sold for $80, then made another $60 fixing it for the buyer, whose brother ran over him with a much bigger board.
Now the, the ignition switch has three positions. Zero, no current flows. Position 1 energizes the ignition and it stays in that position. Position 2 momentarily grounds the starter solenoid, activating the starter. Correct me if I'm wrong, but the coupe switch need do no more (appearance aside, and momentarily ignoring the steering column lock).
