Another option for VDO gauge illumination - now with photos
@ScottAndrews Looks pretty simple, I agree. If I'm understanding you correctly, the rheostat in its standard state in our vehicles is decreasing the voltage flowing between input and output to decrease the brightness of the light. The LM134 is limitng the current, in contrast, thereby allowing modulation of the LED brightness. Your diagram shows that the 12V from the battery goes to the LM134, that output goes to the rheostat but then it appears that both the output that went through rheostat as well as direct out of LM134 are joined to go to LED lamps. So I guess the rheostat is not a 0-100 possibility as it is now but is modulating the total above and beyond that allowed by the LM134?
Also, given that I'd consider myself a beginner-intermediate macro-electrician (i,.e., cars and houses) but a complete novice at micro-electrics (circuit boards et al), is something like the LM134 available in an already-built fashion so someone with my skill level could try it out without having to put together a whole circuit board?
I am not aware of any pre built broads for the LM 134. There may be some small LED drivers available that you could patch in. For example, here's one on eBay. You would need to unsolder the "adjustable resistor, and attach wires that would go to the car switch rheostat. Like this:
LED Driver Board
Ordered. Soldering I can do. I figure if @coupesport can spend a few bucks to experiment with some different bulbs to help guide the rest of us, I can spend $8 and some time to try to rig this up.
Do you have a digital multimeter? If so, measure the resistance of the adjustable resistor. There will (probably) be three pins in a row. Measure the resistance value between the outer pins. If they are arranged in a triangle, then try the various combinations until you get the highest one. If there are two combos that measure the highest, move the adjustment slot and test again.
Then check the resistance of the light switch rheostat (it is functionally the same as the adjustable resistor on the board. However, it may have a different total resistance). Depending on what the difference between the resistors is, you may need to add an additional resistor. This will either be in series or in parallel depending onthe difference between the resistances of the variable resistors.
For example, suppose the one on the board is 1000 ohms, and the one in the car is 500. You will need to add 500 ohms in series withthe car rheostat. This will mean that the LEDS may not dime all the way off, butt hat's probably OK.
If the rheostat in the car is, say 2000 ohms, then you will need to add a 2000 ohm resistor in parallel across the two outer contacts of the rheostat (or solder the resistor onto the board. This will cause the car rheostat to vary between 0 and 1000 ohms instead of 0 to 2000.
Check the board. It is likely that the wiper contact for the variable resistor (usually the middle contact) is connected acted directly too one of the other contacts. In that case run the center wire to one of those two spots.
Post PM if you have a questions.
Scott
Thanks Scott. I do have a digital multimeter and that amount of soldering and assessment is within my skill set. I’ll let you know what I discover once the part arrives.
@coupesport When you had first posted this thread I had ordered the lights you'd indicated since I was planning on cleaning gauge faces etc. I had ordered some from superbrightleds which were a 4-light forward-emitting BA9S base, but I don't see that listed anymore in your writeup. Was that bulb for the telltale lights which you now left as the 4W Osram bulbs?
Also, cleaning the gauge faces makes a big difference. I had to have my clock rebuilt so of course it got cleaned, and with the new LEDs now I'm having to clean all of their interior glass because there's 50 years of some dust which looks quite a bit different than the freshly cleaned one
Hi @e9Leveque,
Below is my final bulb solution after optimizing. Sorry but that initial Superbright 4 LED bulb that I listed did not perform well enough for me in the clock and tach
illumination and so further searching “LED” me to find a superior bulb form PilotLights that I am using for gauge illumination. But you can use quantity 4 that you ordered – see below.
Very glad to hear that your glass cleaning efforts gave noticeable improvement and is likely going to solve my tach being a bit cloudy.
Here is my summary bulb usage, with this you'll get results like Post 13 third picture. Hope this is more clear now. –
PictureBulb specSource
A60 lumen 4 LED 2-way side emitting bulbs.
Warm White.
Quantity 5 or 6
https://www.pilotlights.net/ba9s-bayonet-type-bulb-side-emitter-12v-24v-super-bright
Usage – Illumination, 2 in the fuel/temp gauge, 2 in the Speedo, 1 in the Tach. If you prefer uniformity use 1 in the clock, however, the one below is slightly brighter and was may choice.Twisting the bulb socket you align the 2-way beams to be locally tangent to the circular housing (a reflector ring) for peak brightness. So the beam direction for the speedo’s side(s) mounted LEDs will be vertical and for the tach’s top mounted LEDs align the beam to be horizontal.
PictureBulb SpecSource
B90 lumen 5 LED 4-way side emitting and forward emitting bulb.
Warm White.
BA9S-WWHP5
Quantity 1
https://www.superbrightleds.com/ba9...wer-ba9s-bulb+color-warm~2700k+packamt-single
Usage – Illumination, 1 in the clock, is slightly brightest choice.Twist the bulb socket such that 4 side emitters are diagonal (i.e., the LED beams are neither vertical nor horizontal) to most light being reflected around the interior.
C14 lumen 4 LED forward emitting bulb.
Warm White.
BA9S-WW4-90-12VAC
Quantity 4
https://www.superbrightleds.com/veh...olor-warm~3000k+volts-12v~acdc+packamt-single
Usage4 for the telltale lamps for oil, fuel, brakes and hi-beams.Simple plug-n-play
DOsram 3893 - T4W 12V BA9s = INCANDESCENT
Quantity 1
Many
Usage – 1 for the battery charging telltaleForum knowledge advises keeping this bulb as incandescent because it is not simple on/off like the others and the LED may misbehave.
  • Like
Reactions: Dlc
My last post on this project. I've finished after removing and cleaning the glass in front of the Tach. The cleaning removed the dust and now the Tach has matching color with its neighbors.
Final with LED bulbs in post #27.
With Pilot Lights side emitting BUT clock w 5 way AND Tach glass cleaned.jpg
Original with the 4W Osram bulbs.
Any Issues with these bulbs needing a different relay? Put in blinkers as well. Lights up. No blinking
