Do I hear 10? 5 per side, I think? I am not by my car to confirm - just a vague memory... Or are there (4) for the center grill (kidneys), and the other (6) for the two side grills?6 i think
Fabulous! I am counting the days for the Klausen Pass to reopen and make that drive!i was rallying in that landscape
Yikes! The old baseball bat trick!!! Stay as far away from that one as you can! That's how we used to do it and, unless you are very experienced with it, the results are likely to be marginal at best. Very hard to get a smooth consistent result. And the odds of cracking the paint are significant.Thanks Stephen, your description is pretty much what I imagined, as I've read references to a baseball bat being appropriate for the job!
Apparently, guard rails are optional...Beautiful pics.
Andrew, thanks again for that switch and the recommendation on the heater bypass solenoid. I've started my driving season and during a 2-hour drive through nice winding country roads, I fully appreciated how much heat can build up in the cabin! Nice sunny days, but the air is still crisp, so I had the windows mostly closed and it gets right warm!:eek:If you need a 'fog light/rear defroster' switch for your solenoid heater bypass valve, I have a spare I can send you.
