Assembly sequence example
Lots of bits and pieces in here that are really good advice. I just went through a lot of this myself assembling from scratch, and will give a few bits of my findings:
There is no comprehensive list anywhere I have found, and many steps can be done interchangeably without too many problems. Also, you absolutely will do things over (and maybe over again) despite the best planning: out of order on a small thing, wrong hardware, forgot a part, something doesn't work, etc.
A few areas are critical to do in order. Ones that come to mind are:
  1. running all the hard lines (hydraulics, fuel, etc) before something big like an engine is in the way, but after the subframes/suspension/brakes are in. If you are making these lines, everything you need to connect to must already be in (brakes, master cylinder, etc.), which could change the order for you, and you may want to remove the brake booster after again, before installing the engine.
  2. Easier to install the A/C condensor before the motor, but definitely before the radiator
  3. Running the wiring after insulation, but before most anything else on the interior. I did mine after the pedal box, but probably would have been easier without that in the way
  4. Hook up as much of the fuse block wires as possible (and check them) before sliding it into position. If you want the bulk of wires to go through the mounting bracket, you can actually slide the full wired block through at just the right angle. changing wires once they are through that bracket is difficult
  5. Deal with sunroof drains while the interior is empty as possible, before headliner
  6. Get carpet, upper pillars and headliner in pretty early after wiring. Once the headliner is in, get the interior aluminum trim in place to hold the edge well
  7. Order of the front interior is absolutely critical (carpet, pillar trim, HVAC, dash parts, console. Many of these will only be accessible sequentially. To me, this was the single most important order, and one where we do need a comprehensive step by step. I almost posted one a few weeks ago, probably worth doing one in the DIY section
  8. Make sure everything electrical is working both a piece at a time and in total before you install the upper dash, lower dash, center console sides or lower interior trim. Otherwise you may need to dig/pull apart to solve.
  9. Leave all exterior trim, grills, lights, rubber till very late just in case you need to fix any paint after all that assmbly
  10. Front/rear windows, hood and doors come near the end. As mentioned, trunk is sort of independent (inside and lid), do it whenever you want
Great list, I followed something similar to this.
One note though, Hard fuel line should be made/installed before rear subframe goes on since the fuel line goes over the top of it and into the trunk, very hard or maybe impossible to do after the subframe is in. (at least thats how it is on my '75 3.0CS)
One not though, Hard fuel line should be made/installed before rear subframe goes on since the fuel line goes over the top of it and into the trunk, very hard or maybe impossible to do after the subframe is in. (at least thats how it is on my '75 3.0CS)
Fair, though if you go this route, make sure you know where the subframe, and very importantly the separate front bracket off the subframe is before making it. I had to completely remake mine because that forward bracket was not in place. I didn’t have too much trouble getting it above the subframe, but then again I also went hard mode on the brake lines and made them after the engine was in the car - that was difficult.
@CharlesJ ; great write up!
I'll try and merge all inputs into a DIY thread after we've harvested a few members inputs. And likely it'll continue to expand and get more detailed along the way.
Keep' em coming!
Here's a first attempt. A bit of a compilation/summary of what has been written above:
E9-assembly order
