73bav
New Member
Hey everyone, this is Fabian and I am relatively new to the forum here. I had a long weekend working on the coolant system overhaul on the 72 automatic Bavaria. I have a question about the temp gauge readings. The white lines represent what temperature range in degrees Fahrenheit? I know the temp sensor is based off resistance that the cluster then displays. The reason why I am asking is I believe the temp gauge is reading incorrect. I replaced the radiator with a new mobile tradition unit, converted the thermostat housing to the late style "A" casting with a new OE thermostat (m30b35 e34). I also installed three 10 inch electric fans ( two pullers and one pusher for the aux condenser) set to come on at 90 degree C. The temp switch (new BMW OEM e30) and original sensor sit side by side in the thermostat housing. I cleaned the old temp sensor and Ohm'ed it out and the readings were 620 ohms @ room temp. Then I heated the sensor up with a heat gun while taking readings and it read 34 ohms. (I don't know the max temp the heat gun can produce) Any who, I filled the coolant with 50/50 with a littler water wetter and did a cold bleed first to prime the system. Then ran the engine till operating temp and bled again. I will bleed again tomorrow but I feel the system is mostly air free. All radiator hoses are in good shape with overflow hose flowing.
For those who want to skip the above read here. The engine will idle for a good period of time with the temp increasing slowly. Temp will rise past the first and second white line and go in between second white line and red zone until the fans kick on at 90 degree C then the temp will fall back to the second white line. It will continue this for many cycles but never reaches the red zone. Is 90 degree C really that far up the temp gauge or is the gauge off? The duration of this trial was 30-45 min on a cold 40 degree day. Last thing I checked was the ground from car body to plus on battery and its is a constant 13-13.9 volts while engine is running. Could the cluster have a bad ground that could be misleading me?
Thanks,
Fabian
Thanks,
Fabian
