Blaupunkt 7 Pin cable
Chris- what is the radio's output level? Line level or speaker?
Because I used the speaker outputs, I had a higher level than what a modern amp was designed to handle. So I used a line level output converter with a signal trigger to take the feed from my Becker Europa to input to a modern amp. It works well and will turn the amp on and off with the radio. Here's an example and it's about the same price.
http://www.walmart.com/ip/PAC-SOEM-...bucket_id=irsbucketdefault&findingMethod=p13n
