I have an m30b35 M30 in my e9.
It had the blocking plate on rear of head, but given use in my e9, now has the coolant pipe attached, which goes into the heater core, then out of the heater core, into the csi style solid pipe, running along the engine block. (I am running triple webers, no choke)
I have 2 questions.
1- what is the flow direction of the coolant here? Is it leaving the top of the head (hot), going through the heater core, and back out through the pipe along the engine block ( a tad cooler ) , or the other way around?
2 - is the correct installation of the pipe coming from the back of the head, to be attached to the lower inlet of the heater core? (close look at real oem diagram , would appear to show this). And why would this be, hot water wanting to rise??? (i know i sound stupid , but lets not go there, my wife already does a good job of that!)
I plan on using a simple in line block off valve, to stop flow into the heater core during summer, and want to confirm best pipe to install it on.
I know there is debate about a block off valve, or a flow re route valve to keep the flow through back of head, but given m30b35 had a blocking plate as original, and I believe e3/ e12 / e28 had block off valves (rather than flow re route), for this purpose, I cannot see an issue, but chime in if you have a very strong opinion.
Thanks in advance,
Mike
I have 2 questions.
Thanks in advance,
Mike
