It's finally available!! We’ve resurrected the marvelous BMW Engine Turning Tool #7008-1. We used 4140 steel and had it hardened to RC 48/52 tool grade steel. We then had it black oxide treated to produce a long lasting, corrosion-resistant finish. This is one of those tools that will be passed down for generations.
Need to adjust your valves? Set the dwell angle on your points? Find TDC to stab a distributor?
You could use the old methods of turning the engine:
The Engine Turning Tool works with any dual-row timing chain used on BMWs from the 60s to the 90s.
Order yours today on our updated e-commerce website: https://www.2002sonly.com/product-page/timing-chain-rotation-tool
- Put the car in fourth and push it (unless it’s on a slope)
- Bump the motor with the starter (never stops where you want it to!)
- Push on the fan blade (bad for the fan and your knuckles!)
- Try to get a socket on the crankshaft nut (requires two people)
