body grommets
m5bb
Peachtree Corners, GA
Guess you mean the wiring harness where is goes through the firewall.
So, no I don't know where to get the oval shaped one where the major bundle of wires goes through.
I am going to slice through mine at the bottom and hopefully put it back.
Some of the others that are like plugs (bolt access for hood latch) you can measure and find in parts diagrams for other models.
I found the ones mentioned in E28 parts.
Some others in E24 and maybe some in the 2002 or E21.
A place called Nostalgic Air has some general grommets that might be helpful.
Gary
79aggie
Dunn Loring (Washington D.C.)
Grommets
There are a few grommets in the front section along the wiring harness.
A few through the front cowling, a couple each side for the brake lines through the inner fender. To name few.
My ova through the firewalll is in good shape though.
Ohmess
I wanna DRIVE!
Aiken, SC
I have actually have pretty good luck removing mine, cleaning them and rubbing them with vaseline. They came out pliable and look pretty good.
