I think it's time to redo my brakes. No idea when last they were done but I note: front left rotor is warped and is getting hot but measures well over minimum .750, has not been cut; front left caliper appears to be sticking on at least one piston;  front pads are 90%; rear pads are pretty much at the EOL; rear rotors are at .650 which is below minimum .709 (18mm); left rear is getting a little warmer than the right rear. Rubber hoses are not cracked but look old. No leaks apparent. Braided hose from fluid reservoir to master cyl looks very old.
So questions:
1. Is it advisable to use a seal kit to rebuild sticky calipers, or is that a waste of time. WN has caliper rebuild kits, they seem to be reasonably priced.
2. Am I correct in my finding that rotor min is 18 front and back? Normally on other performance cars, rears can go thinner.
3. WN is out of rear rotors (well they only have the cross drilled type and I don't see the need for that); who is the best US source for rotors and calipers, if needed? Is there a rebuilder in the USA that knows what they are doing?
4. Are those "anti squeal" pad shims necessary? Front and back?
5. My rear hub has a little rotational play which seems to be mainly in the outer CV joint. Is this normal?
6. Rubber hoses ... how to tell when they are done?
			So questions:
